Bryston BP 4.2 questions
0 Members and 1 Guest are viewing this topic. Read 1307 times.
colhogan
« on: 2 Sep 2014, 11:55 pm »
James:
 I recently picked up a used BP 4,2 from "Flebay".
The price was right,so I figured,"Why not'? The only physical issue,other than some scratches,is that the green LED light does not work. It looks a little bent.
 Here is my question:
 I am using a 2B LP with RCA inputs,and I noticed that when I used the BP 4.2's XLR Outputs, the sound to the 2B was quite muffled.
This does not happen when using the BP 4.2's RCA Outputs.,(Thankfully.)
 I bought the RCA to XLR cables already wired,and I wonder if that is the cause.
 All the other inputs/outputs of the unit seem to work fine.
 Any help you can offer is greatly appreciated.
 Patrick
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston BP 4.2 questions
« Reply #1 on: 3 Sep 2014, 12:03 am »
James:
 Patrick
Hi Patrick
It sounds like it might be the cables as both left and right sides not working would seem slight.  There is no advantage to using a Balanced to RCA cable anyway as the sending and receiving unit must be balanced.
james
colhogan
« Reply #2 on: 3 Sep 2014, 12:15 am »
Thanks for your help-, James!
