Audio/Video Gear and Systems
The Lab
sts9fan
Methods in securing acoustic foam tiles to ceiling
0 Members and 1 Guest are viewing this topic. Read 1605 times.
Lost81
2 Sep 2004, 10:37 pm »
What is the best way to secure / attach acoustic foam tiles to the ceiling?
Is it better to glue the foam tiles to some sort of backing-boards and then attach it to the ceiling with wood screws or velcro?
Or will using drawing pins to secure them to the ceiling simply suffice?
Many thanks!
-Lost81
warnerwh
3 Sep 2004, 05:21 am »
Just go get some spray adhesive from Home Depot. This works well and they can be removed later if you move without damage. I use the 3M multipurpose stuff.
Volunteer
Green Bay Packers
Reply #2 on:
3 Sep 2004, 11:59 am »
Some glues may eat the foam for lunch. Make sure you get the stuff suitable for foam. It may be difficult to hold the foam on the ceiling while it dries. If so, you could attach them to peg board then fasten them to the ceiling with screws.
MikeTz
Reply #3 on:
11 Sep 2004, 02:39 am »
This stuff works pretty well if your ceiling finish is flat (no styrofoam acoustic popcorn texture):
http://www.auralex.com/acoustic_adhesive_foamtak/acoustic_adhesive_foamtak.asp
Good luck
MT
The Lab
sts9fan
