0 Members and 1 Guest are viewing this topic. Read 6946 times.
I believe that Ryan and Pete were speaker builders first and became speaker building businessmen. They put the same enthusiasm and knowledge into their products for others that they would if they were for them. They are both extremely knowledgeable and have grown their capabilities since they started. I admire and respect both of them. Some day I would like to build speakers as good as theirs. I am not an owner but have listened to their speakers several times. You will not be sorry if you give them a chance to share their product with you.Howard
If their speakers hit the right spot for you, the value you get with vapor is far better than traditionally marketed speakers. The design and implementation are 1st class too. They should be on everyone's short list imo... not saying they are a one size fits all solution to audio, but if you like the sound they are going for they are hard to beat.
Thanks DaveC113.Are you a Vapor owner or have you listened to Vapor speakers?Sonically, which are the strong points of Vapor speakers and where do you see room for improvement? Are there other companies that produce similar sound to Vapor?
Yes, I would take a TAD Ref 1 over Vapor, but it's going to take that kind of budget (the TADs are $90k) to do significantly better imo.
Sonically, which are the strong points of Vapor speakers and which are the qualities that are not so great and could be improved? Is the RAAL twitter the component that makes a (positive) difference or not so?Thanks.
I'm not sure your question is going to get useful answers because it is VERY subjective. For instance, some will love the RAAL ribbon for it's detail and accuracy, others may prefer a smoother, more laid back sound. Neither one is "right". But, it could be interesting to hear opinions on the subject. For me, I prefer detail and accuracy over a rolled-off smooth sound so I like a GOOD ribbon tweeter, which the RAALs are.
RMAF as well...
Hmm. Pretty sure they were not there.
I am asking, because I have not had the opportunity to hear a ribbon tweeter yet. I wonder whether it gives a sound similar to electrostatics. Is that a fair description of the RAAL tweeter?Thanks
I did not specify which year. Do you think I'm just talking out my a$$ and are trying to call me out?
What year was it?Sticky side down.
Answer my question first. ...because I'm very close to putting you on ignore.
