0 Members and 1 Guest are viewing this topic. Read 12242 times.
F3 of 43 - 46 Hz could be overwhelming on a desktop
Speaker F3 needs to be matched to room size
Budget for powered/active is $900 - $1000.Is there a general kind of guide for F3 value vs. room size?I am going to move to a larger room (11'x16') and will be able to set up along long wall, but again, desk will be pushed close to the wall. Still forced to be in a desktop-type setup though as I do not prefer speakers behind or to the side - must be in front, even for low level listening. I am weird that way JLM - Thanks for the suggestions! jk@home - Have not heard those yet, but even used they sell for over my budget. Then I'd have to also get amps for them. And a sub, correct? Or are you satisfied without a sub? Their spec indicates they do not play much low freqs. at all, correct?
not sure about tethering DAC/speakers together
can only listen to their canned music, most of the speakers are far less than ideally located); none of the better monitors they show on their website
