0 Members and 1 Guest are viewing this topic. Read 19253 times.
You really should go listen to them. Ultimately, posting in the Vapor circle is not going to help. There are now plenty of places to listen to them.
I would love to listen to them. I am quite curious. My practical limitation is that I live in Europe (Greece in particular). I understand that they are not so common in Europe... -(
OK, I get it (I think). Should the speakers fly over to me or should I fly to the speakers?Cheers -))
I have never heard the Croft amplifier but they are interesting hybrid amps... I think there is more likelihood the Croft would let the Cirrus down than the other way around, my Cirrus have sounded phenomenal with anything I have in front of them... For a room that size if you want "full range" sound I would suggest the Joule, the Nimbus, or the Derecho. I have heard all except the Derecho at this point on various amps at various shows and listening parties.
I also bought my Cirrus Blacks unheard and while most would frown on such a move I have no regrets. Please note I did have a chance to hear a pair of Nimbus speakers to give me some idea of what Vapor can do.
Yes? What can a Nimbus do? Any better that the Cirrus?Cheers.
Hello pankon, quite a few questions here so I'll do my best to answer them all. ...Pair with your amplifier, I was unfamiliar so looked up the specs. At 45wpc it will work nicely with anything in our lineup. Sensitivity isn't our top priority, but it is a priority. So most of the models in our line are more sensitive than similar offerings from competitors.
...A 15'x22' room is a good size, anything in our line can be made to work quite well in that space. The Nimbus even would work just fine. But as with any speaker, the room plays a huge role in the final sound. Room treatments can almost always improve things, and we're happy to help you make those decisions. A few pictures of the room and we can give some specific recommendations. As far as choosing which speaker is right for you, we can tell differences in their capabilities but ultimately it's up to you based on budget and other considerations. There is a long wait for Nimbus orders right now, but it's obvious why - where else can you find a speaker that offers even a fraction of what it does for the price? ...
Yes, the Croft are quite capable of driving rather insensitive speakers. One example is my Harbeth P3ESR which are less than 84db/W/m, if I remember correctly. The Croft amps do not show absolutely any strain with the Harbeths.
Yes, value-for-money is a priority for me. I am not a bass freak, so I am not sure whether extreme low end (which usually comes at a price) should be my ultimate objective. I listen to classical rock, 60's-70's phychedelia, R&B, Jazz (less). I prefer to be able to 'touch' the singer, instead of feeling the thump on my chest.So, what's your initial diagnosis? I feel that Nimbus is beyond my reach, especially due to its size and weight (transportation cost), as well as customs duties into European Union. So, what is still there? Cirrus Black or even Stiff Breeze?In case you are familiar with the Harbeth sound (or the classical BBC sound), how would you compare the Vapor sound with that?Cheers.
