0 Members and 1 Guest are viewing this topic. Read 19255 times.
Recently I have read quite impressive reviews about Vapor speakers and I am intrigued. Maybe they would be a better choice compared to the Harbeth or the KEF LS50, which I am thinking of buying.My amps are a Croft Micro25 pre-amp (valve) and a Croft Series7 amp (hybrid). Does anyone have experience with a Croft / Vapor combination?And which Vapor model? Which 'color'? Black or white?Thanks.
...I cannot comment on Vapor as I haven't heard them......BUT wow, the bang for the buck is through the roof. Hard to go wrong here....
Thanks, RDavidson. I am not looking at hi-fi audio as a 'sport' or a competition, where you always need to do better, and especially better than others. As long as I find a piece of equipment, which is pleasing to my ears, lets me enjoy the music and is reasonably priced, then I can eagerly choose that piece and live with it piece for many, many years, perhaps for ever. Why 'upgrade'? Why should I need that? To show off my expensive hi-fi system to my buddies or demonstrate my 'knowledge' of the domain? Well, that's not me.My amplifiers are hand-made by Glenn Croft, a genius in the UK, who's been building valve amplifiers for 30 years now. No frills, no special/expensive looks, no remote control, but beguiling, immersive sound and a terrific value for money. And I do not mind that Croft is more of a one-man show than a huge company. I love hand-made objects.I expect the same special attention to detail from Vapor. It seems that Vapor also love what they do. And feeling proud of what one does and offers, whether it's goods or services, can be a very strong driver for excellence.I hope that the Vapor speakers can be another revelation for me, just like my beloved Croft amps were in 1989, when I first bought my Croft SuperMicro preamp.
Hmmmm.......not sure where my suggestions lead you to believe that you should "upgrade for sport" or should do so to "show off." I buy what I like and could care less what others think, too. Sometimes I upgrade equipment because there's better to be had or I'd like to try something different. I think this is the case for most in this hobby. Sometimes lifestyle changes force system changes. Everyone has their reasons for their choices. You never expressed your position, so I made general recommendations as well as offered suggestions on how you might find the best way to the end of your audio journey. We all know there is no absolute BEST, so if you came here honestly asking "What's best?" ,only you know what is best for you. Typically this takes some trial and error. You never even told us what speakers you currently have, nor your room size, nor the types of music you mostly enjoy. Soooooo?
No problem. Thank you for the clarification. Also, thank you for posting your system components.Looks like you prefer speakers on the slightly warm and inviting side. Me too.What I suggest is talking to Vapor. I kind of forgot about this, but aside from aesthetic choices, they can also make parts changes / upgrades (ie, change internal wiring, caps, binding posts, etc. etc.) to tailor fit you as best possible. With something tailored to your wants / needs and built to such a high level, you'd have a very difficult time going wrong.
I am already in touch with Ryan about a Cirrus Black. It's a bit difficult to customize a sound that I have not ever heard, but what I imagine is the clarity of an electrostatic (the ribbon twitter) combined with the dynamics of a good box speaker.I am looking forward to pairing a set of Cirrus with my trusted Croft amplifiers. My instinct tells me it can be an thrilling match.Cheers.
...If your budget comfortably affords it I can't help but recommend you consider the significantly more efficient Nimbus and some GIK room treatments (under advisement of GIK and Nimbus) to go with your future Croft. ...
Get the Joul, Add 2 Smaller Subs into the room to give it an extra push on the lowest octaves.
I understand the idea behind that suggestion, but in reality I can't say that I've ever heard bass as tuneful and accurate as that from the Joule. Troels in his work agrees that the AudioTech Sandwich cone 10C77 is the finest woofer of that size available, but when you combine it with a smoothly tapering Transmission Line (not to be confused with other companies stepped TL's, or Quarter Wave TL's) that nearly completely eliminates midrange resonances, the result is better than any subwoofer setup I've yet heard. Honestly if you wanted more bottom end reinforcement from the Joule, the proper way to do it would be have us build a pair of subs with the 13" AT Sandwich Cone and put them in a stand-alone 10:1 tapering TL stacked-ply cabinet.
