0 Members and 1 Guest are viewing this topic. Read 7786 times.
Upgrading your power amp to a stereo N-Core amp would probably be a pretty significant difference.
Yes, you are right. The NCore would make a significant difference - but in the wrong direction. Salk speakers and Ncore amps do not mate well. Been there, done that.Wayne
Start with the sources because they affect every other component. Replace the 103 and also buy the best DAC you can afford.
I had to do this. I quickly placed my home theater Song Towers in with my main system. I'm using a Mac mini, Lampizator Big 7, Lampizator Pre and powering with a First Watt SIT2. 10 watts!! Call me crazy but it sounds amazing. (Listening to Harry Hood from the Gorge last summer.) I can imagine needing any more bass or volume my floors are shaking. I do have a lot of bass trapping, and i agree with others this could be the best money spent. A great source, good clean class A power will make a huge difference. For reference I had SS8's with w4s sx1000s AND i had HT2tls with an AVA 400r. My sound with the above set up is on par with either of the "better" speakers. Honestly even better to me now. Tone, soundstage, depth will outweigh power, bass and measurements. It's a much more sustainable long term listening habit or appreciation from my experience. But we all have our own paths and i needed to go through what i did to get to where i am. And most importantly we all have our own taste.
