0 Members and 1 Guest are viewing this topic. Read 4382 times.
Hi Jim,Jelco didn't make Alphason or Zeta. Both were made in England. Nice looking table there. neo
Not as certain as I could be about the Zeta, but I think you are mistaken about the Alphason. Research em. I've spoken with their Canadian importer, also. Thanks for checkin out me table. It's a rather old Micro Seiki BL91. Massive it is but with a spring suspended motor. Clever buggers. Two minutes later. I did not see Alphason with my search, after all, but do believe I read that somewhere. Does the Alphason have a removable headshell? Think they made Oracle and Sumiko arms, no? Plus Linn.
Or keep it....get an external Phono upgrade.Just my opinion if it were mine and I had the $$ to spend.
I was confused . Thanks for the clarification, fellas.
Right now I'm using the internal phone stage in my AVA UltraII. It's quite nice with the NOS Telefunkins stuck in there. The sound I'm getting from my system is quite satifying. Just got the itch to do some modding
Yeah, you could do much better than the AVA. Upgrade your phono stage first to a dedicated outboard unit. There are many great ones to choose from in the $1500 ballpark (new or used) that will blow your doors off.
One last thing. In it's most basic form can this thing be made better with a new tonearm? something that can be heard easily.thanksRic
Probably, but you have mechanical considerations here and possibilities might be severely limited. All this talk of upgrading this or that, did you mention your cartridge(s) ? I think it would make sense to look at the big picture, as it were. Phono stage/cartridge/arm synergy is critical. neo
Scout 1.1 - not a bad idea. There are others in the price range too, quite a few actually. You're in a good position now. With the table you already have, you can sit back until the right deal comes along. Maybe you can pick up a demo or find a much more expensive used table. I'd be inclined to look for used, but that's not for everybody. I always see deals on Audiogon that get me thinking. Like a Classic 1 (walnut) w/DV20XH/clamp/dustcover - $2500. If you really want to tinker, Avid Volvere without arm -$2600. Well Tempered Amadeus - $1825. Have fun,neo
