0 Members and 1 Guest are viewing this topic. Read 8091 times.
Your math is off. ..... At 0.5oz cost per serving is $1.20Sure its not cheap and maybe I will never buy it again. Though not nearly as much $$$ as you posted.
mamba, I think this stuff is about 6-10x more concentrated than typical cold brew coffee!
What makes this different from "regular" cold brew coffee?We make cold brew sometimes at the restaurant I work in. It is regarded as rocket fuel by even the most jaded coffee drinkers. I prefer it straight, but no more than 1 oz! Despite it's concentrated nature , it is much easier on the stomach than hot brew.Very easy to make: soak your regular coffee beans in water for 24 hours and then strain. Helps to use a coarser grind so the filter doesn't clog too bad.Of course, with daily consumption you will get used to the kick. Best to have it as an occasional treat
