0 Members and 1 Guest are viewing this topic. Read 56427 times.
did you see my question on why a 1m Optical USB cable?
OKSorry to hear. I was going to pitch for a 2m cable length…one size fits all kinda thing.
It's everything working great except i can't get DS lighting to read more files from my NAS,it only recognize about 500 albums ,I got over 2 TB on my NAS.It's there a way to get them to recognized the rest of my NAS?Thankslapsan
What specific NAS do you guys recommend to go with the Aries? My library is currently about 3.5TB and growing. Thanks.
Are you using Minimserver on your NAS? If so, what does the log show?
yes,i use minimserver on Qnap 210.it's only 3 folders,it have 7 folders total.It's only show half the # of files on 1 folders and 2 smaller folders.the other 4 didn't show up at all.i try refresh the NAS from lighting DS so many time and still read the same folder.Thankslapsan
DSL?
It sounds like the other folders aren't shared. Maybe?Check your Minimserver (through Minimwatch) log and it should like this: Thank you ,that fix it
