Re: How to Do It Yourself in Computer Audio
0 Members and 1 Guest are viewing this topic. Read 1496 times.
sts9fan
« on: 1 Apr 2014, 12:52 am »
Can anyone help me out getting started with a D2800MT CAPS?
http://www.intel.com/content/www/us/en/motherboards/desktop-motherboards/desktop-board-dn2800mt.html
Not sure the steps to take to get OS on etc.
Doublej
Re: Re: How to Do It Yourself in Computer Audio
« Reply #1 on: 1 Apr 2014, 01:29 am »
What OS do you want on it? Are you aware that is has been end of lifed? I'd recommend you purchase an Intel NUC where all you have to do is add disk, memory and an OS and you're good to go but since that not what you asked, I'll point you to the interactive board demo and step through it.
http://www.intel.com/content/www/us/en/desktops/desktop-board-dn2800mt-interactive-layout-demo-video.html
0. You'll probably want to install this board in a case. You can scour the web for one that suits your fancy.
1. You need to get 19V to the board. (Number 34). So you need to find a 19V power supply, paying special attention to getting the proper tip size for the connector.
2. You need a SATA disk drive. Number 8 is for powering it, 7 is for the data cable.
3. You need RAM. Plug the DIMMs into number 16.
4. Does it come with a coin cell battery installed, number 4? If not you'll want one of these so your settings don't go bye bye when you lose power to the board.
5. Now you are ready to install an OS. Which one do you want? You'll need to get the computer to recognize wherever the OS installation program is located. In this case you'll need to put the OS onto a USB drive or stick and configure the computer BIOS to be bootable from the USB port.
6. Once you have the base OS installed you can use the wired network port to get network connectivity to update the computer's drivers and get updates to the operating system.
7. You have two slots (numbers 9 and 24) to add cards. For example if you want to add a wireless card see number 9.
There are build instructions on the website. There's probably a ton of stuff on Youtube as well.
http://www.intel.com/support/motherboards/desktop/sb/CS-020834.htm
P.S. We bought one of the newer Intel NUCs at work. Nice sleek little machine that makes the Mac Mini look obese.
If you want a real cheapie, here's a barebones with case and power supply for $140! Personally I spend another $125 to get one that's half the height on the one below.
http://www.amazon.com/Intel-DN2820FYKH-Celeron-N2820-support/dp/B00HVKLSVC
Helpful?
sts9fan
« Reply #2 on: 1 Apr 2014, 01:47 am »
Yes, I have it in a case and with a 12v supply. When attached to a VGA monitor can't get to the bios. I should be able to without a drive or os, correct?
sts9fan
« Reply #3 on: 1 Apr 2014, 01:50 am »
I assume the is should be the only thing on the flash drive. ?
Doublej
« Reply #4 on: 1 Apr 2014, 02:21 am »
You might not be able to get to the bios if you don't have RAM installed and/or disk drive installed but I am not sure. Or it might be because the board is desiring 19V and you are only giving it 12V.
Here's a couple of  troubleshooting links.
http://www.intel.com/support/motherboards/desktop/sb/CS-010254.htm
http://www.intel.com/support/motherboards/desktop/sb/CS-029511.htm
Yes the OS should be the only thing on the flash drive but the flash drive also needs to be configured properly so the computer can boot it. What OS are you trying to install?
sts9fan
« Reply #5 on: 1 Apr 2014, 02:29 am »
8.1pro but I have not obtained it yet.
Doublej
« Reply #6 on: 1 Apr 2014, 11:19 am »
Google or "Install Windows 8.1 from Flash Drive" for details on how to install Windows 8.1 from a USB Stick.
toddbagwell
« Reply #7 on: 1 Apr 2014, 11:45 am »
I split this out of the DIY sticky, I think it will do well as a stand alone thread.
As to installing from a USB stick:
http://www.maximumpc.com/article/features/how_install_windows_8_flash_drive_31384
