0 Members and 1 Guest are viewing this topic. Read 13287 times.
Hey all. So I have my Omega 3 bookshelf (wide baffle) with RS5. As you may know I have a MP301MKII SET amp. It is amazing. Now I want to know what speaker cable tweaks there are. I would describe my set up as surgically precise with loads of micro detail. I want the detail and to tone down or maybe it is warm up the upper end a bit more. I have read or been told that Omega's like certain properties in speaker cables just like they like a certain amplifier. High current?
Has anyone tried Analysis + ? They have very nice low end; the spendy ones. I'm still trying to get a better idea why they work well, without taking them apart haha.
I don't agree that you can't have warmth and also detail. From experience I would avoid solid core cables with Omega speakers. They can be hard edged at the upper frequencies which will only augment your 'clinical' trait more. Because Omegas are efficient and don't use large drivers, you don't need to go for too large a gauge in your cables. So my advice would be to use a multi-stranded ohno-cast wire with gold-platted copper connectors. This should steer you on the path to neutrality fairly swiftly.Also re power conditioning, that's not going to cure any hums or buzzing you may have. This is a sign of issues elsewhere (most likely grounding issues).
