I'm having a little trouble understanding the question... on the one hand, you say you want an Air as a music server and won't consider a Mini, and then you ask if the display in the Air will cause noise problems. Why not just side-step the problem and get a computer without a display? (That would be called a mini).I don't have anything against the Air, I love it (or I did, when I had one) but I can't understand why it would be purchased specifically for a dedicated music server.
You might want to consider that setup, but using a NAS drive to store the music. You could save money on the size of the SSD that way, and you can easily (and cheaply) have more than 500gb of music that way. It also opens you up to maybe adding players in other rooms or something down the road.You could still have the exact same workflow you described, you would just tell iTunes to get its library from the NAS. It would be transparent a user after initial setup.
Flash,The SSD is the best way to go, obviously. You have that covered.You might consider getting some nice interconnects. If you let the display 'sleep' thru the 'energy saving' option. I think you can make the display sleep after 1 minute. So display noise would be nulled. If in fact there is any. ( The odds that you get a noisy display is small. Possible, but very small. )I would think the only thing left, would be the quality of the actual music being streamed or played. Everyone has there opinion on that. Options are almost endless. Maybe others could chime in.Good luck, hope I didn't kill your thread.
Flashman : would be happy to make some suggestions as to how to optimize a MBA as a music server, but I think it would be a disservice to you to not address your assumption that a MBA makes the best server per your requirements. The two main issues being ease of use / convenience, and the other, sound quality.As to the convenience issue : it's been my experience that the most user friendly way for the non-technically inclined to operate a modern stereo system is to use a smart phone or tablet as the control mechanism : particularly whatever the user already owns and is familiar with. So, for example, if your spouse or other users have iPhones or iPads, then the free apple Remote app. To use these applications - whether on an apple or non-apple device - it's not important whether you're using a laptop or desktop. The streamer / server becomes functionally invisible to the user. I personally think a spouse / child / guest etc would much prefer to use their existing portable device than trying to navigate iTunes or whatever on someones laptop. And it's in their pocket / purse and they don't have to leave their chair.
Your run of the mill laptop is potentially one of the worst offenders in this regard, a complex machine with many parts producing noise in close proximity with each other : screen, processor, circuit board, battery, etc.
By placing the track into memory you're reducing many of the noxious effects of a conventional hard drive.
flashman, thx for the info on bluesound node, that looks very appealing to me. I have had my eye on the olive one, but who knows when that will come? one of my concerns is jitter in the system and cant find any measurements on the Node. thx
I don't know Flashman, I think you should probably stick to your original plan if you want your wife to participate. Ask her which method she would rather use and make it work for her. Otherwise, you will end up with a pile of gear and an unhappy wife. And it probably won't sound all that much better (different?) either. Maybe I am wrong. Just a gut feel.I have a couple of honest and sincere questions on this subject if it is OK to tag along.How is a Mac mini clearly less noisy than a MBA in real terms? I mean, a Mac mini is also a complex machine with many noise producing parts in close proximity to one another. I don't see a real difference here.How does memory play eliminate the noxious effects of a conventional hard drive? If the music originated from a noxious component, shouldn't it still have the same noxious embedded signature when played back by a superior component? I really don't understand how moving things around in the digital domain can improve or repair timing or noise issues. It seems like the more you mess with it, the further you get away from what it was to begin with. That has been my experience anyway.And lastly, streaming. If you really want to hear the best sound, isn't streaming just another conversion process? I would think that streaming would be on the "avoid" list for best sound quality. It is certainly more convenient, I do understand that.I know, I still have a lot to learn. I do want to get back into this though. I hope to learn from other people as well.
I did a bit of searching on the Internet and found lots of stuff, but one that has me intrigued is Bluesound, which is produced by the parent company of NAD and PSB. They have a slew of products but one that seems quite interesting is the Node (http://www.bluesound.com/products/node) for only $499. It can play hi-rez files up to 24/196 and stream Internet radio. Interestingly, it does not have USB out but instead has S/PDIF (optical) out, which means I could connect it to the hi-rez capable DAC in the Hegel H80 integrated amp. That way I could get full 24/196 vs using USB, which is restricted to 24/96. I would connect the Node to a NAS with all my music. Apparently, they have a slick app for both iOS and Android. Since this is a Mac forum, I may set up a different topic on AudioCircle to discuss this option.
