Bda/Bdp Tweeks
0 Members and 1 Guest are viewing this topic. Read 1779 times.
werd
Bda/Bdp Tweeks
« on: 2 Mar 2014, 02:53 am »
I challenge anybody with either of  these two units to try this, Open both covers, using the appropriate size torex (Easily get at a Canadian tire). Loosen all the torex heads holding down the transformers, and the pcb boards. You can even do it while its playing its so easy.
Everything factory comes tighten down to much. Loosen it up for nicer relaxed sound that keeps the sounds stage nice and tight. The effect is immediate but leave it like that for at least a week to see if you like it.
here's a recent pic
Mag
Re: Bda/Bdp Tweeks
« Reply #1 on: 2 Mar 2014, 04:26 pm »
No Werd, I don't think I could detect the loosening of a few screws or a cable swap :P
But I betcha I can tell if there's a 3 decibel increase in volume.
What happened to your TV, and what's that a bass guitar?
Can you play Methademic? :rotflmao:
sweetspot
Re: Bda/Bdp Tweeks
« Reply #2 on: 2 Mar 2014, 04:40 pm »
OMG, Is this what it's come to!!!! :o
srb
Re: Bda/Bdp Tweeks
« Reply #3 on: 2 Mar 2014, 04:57 pm »
Don't forget to loosen the screws in your wall outlet receptacles and cover plates.
PRELUDE
Re: Bda/Bdp Tweeks
« Reply #4 on: 2 Mar 2014, 06:08 pm »
Where is Mr. Green when we need him? :green:
Reply # 103
http://www.audiocircle.com/index.php?topic=111759.100
werd
Re: Bda/Bdp Tweeks
« Reply #5 on: 2 Mar 2014, 09:41 pm »
 :rotflmao: Probably.
werd
Re: Bda/Bdp Tweeks
« Reply #6 on: 2 Mar 2014, 10:06 pm »
Come by and listen to my 14B for awhile. After a couple of hours I will get my battery drill and loosen/tighten the outlet powering my amp. Its almost like a bass tone control.
unincognito
    • bryston.com
Re: Bda/Bdp Tweeks
« Reply #7 on: 2 Mar 2014, 10:46 pm »
Why stop at just your home, call up your service provider and see if they won't loosen up the bolts holding down the giant power generators.
Cheers
Chris
werd
Re: Bda/Bdp Tweeks
« Reply #8 on: 2 Mar 2014, 10:51 pm »
Cheers
Chris
Holy Christ! lol I thought about that. It didn't seem possible.
werd
Re: Bda/Bdp Tweeks
« Reply #9 on: 2 Mar 2014, 11:37 pm »
Reply # 103
Thanks for finding that.
konut
Re: Bda/Bdp Tweeks
« Reply #10 on: 3 Mar 2014, 12:33 am »
Thanks for the tip, but I've already got more loose screws than I know what to do with. If I was any more relaxed, I'd be in a coma.
werd
Re: Bda/Bdp Tweeks
« Reply #11 on: 3 Mar 2014, 02:33 am »
Every time I tighten one another one gets loose. Ha. No seriously, everything comes from the factory just tightened down to much. This stuff needs to be adjusted in people's homes after purchase. Its was pointed out by Michael Green and its real. It takes about 5 minutes too and it will change what you hear. If not, tighten it back up.
