7BSST² Upgrades
0 Members and 1 Guest are viewing this topic. Read 1730 times.
Fullvolume
7BSST² Upgrades
« on: 28 Feb 2014, 12:43 am »
I'm considering getting my 7BSST²'s upgraded with the new transformer and capacitors. I'm wondering is there any other upgrades that can be performed while my amps would be in the Bryston shop.
Have there been any other improvements since 2010 besides the 2 mentioned?
  • The Demo is Everything!
    • http://www.bryston.com
Re: 7BSST² Upgrades
« Reply #1 on: 28 Feb 2014, 01:13 am »
Hi
Yes check with Mike on that as I believe there are a couple of small parts changes on the circuit boards we have added as well.
james
95Dyna
Re: 7BSST² Upgrades
« Reply #2 on: 28 Feb 2014, 10:00 pm »
Your 7's are pre S/N 001825, correct?  Please don't tell me there has be an upgrade to > 001825  :|
Fullvolume
Re: 7BSST² Upgrades
« Reply #3 on: 28 Feb 2014, 10:31 pm »
My 7's are pre S/N 001825. I talked to Mike P and he said there has been a few updates since 2010. He never stated what they are but these updates are performed at no charge when getting the transformer/caps upgrade.
95Dyna
Re: 7BSST² Upgrades
« Reply #4 on: 1 Mar 2014, 03:02 am »
I have 001850 and 001851 with the transformer/caps upgrade and would certainly be interested in what other updates have occurred since then.  Did Mike describe the updates?
Fullvolume
Re: 7BSST² Upgrades
« Reply #5 on: 1 Mar 2014, 04:18 pm »
He did not.
1oldguy
Re: 7BSST² Upgrades
« Reply #6 on: 15 Apr 2014, 02:37 am »
Mine are 1843 to 1847....Wondering the same about exactly when the changes occurred.
