Audio/Video Gear and Systems
The Lab
sts9fan
White Lightening speaker cable fix
0 Members and 1 Guest are viewing this topic. Read 1035 times.
Folsom
Restricted
26 Feb 2014, 08:29 pm »
I know some of you use them, as do I.
Recently I cut off the outer jacket and removed the ground wire.
Elevate with wood from ground if you got carpet.
It's better.
bregez
Re: White Lightening speaker cable fix
15 Mar 2014, 11:42 pm »
So you are only using the black wire for the common and the white wire for the red?
This is assuming that the green is the ground wire.
When you say removed do you mean removed from the circuit or physically removed it from the outer jacket?
Folsom
Restricted
Reply #2 on:
16 Mar 2014, 12:56 am »
Physical.
I tried from circuit first, but something was off. Removing physically seems improved to me.
The Lab
sts9fan
