0 Members and 1 Guest are viewing this topic. Read 5682 times.
So many on here, don't have a clue... http://www.diysoundgroup.com/
What do you mean they don't have a clue?
I know nothing about what is reputed as good on it. Some have designers that are known but I am ignorant of them.
Ah ha, so its you that don't have a clue.
Or one of Jeff Bagby's kits on diysoundgroup.com.http://www.diysoundgroup.com/waveguide-speaker-kits/fusion-series-kits/fusion12-kit.html
Bet that would be a fun speaker - lacking in resolution, detail retrieval, and sweetness up top ... but likely have excellent mid-bass reproduction and dynamics. Also very room friendly. I would add a layer of 3/4" Birch Ply behind the MDF on the baffle, cut and flush trim the holes to match. Make the ply layer the same width/height as the cabinet opening so it'll rabbet into the front. Then overbuild the cabinet with thick walls and plenty of bracing.
