New Speaker Project Ideas?
0 Members and 1 Guest are viewing this topic. Read 5683 times.
Folsom
Re: New Speaker Project Ideas?
« Reply #20 on: 26 Feb 2014, 08:10 pm »
Will do. I want the better posts for the speakers too, but I'm not sure if the flat packs are cut for whatever.
« Reply #21 on: 27 Feb 2014, 12:27 am »
You  mean the  tube connectores  right ?   If the  flat packs are already cut,  you  could always install the standard cup   in the hole and even wire the cup and  tube connectors in  parallel so yu could actually compare them.. Just put the  tube connectores slightly above the standard cup.  The male ends of the tube connectors will fit in a standard binding post.  Danny has a sticky in his circle  about the tube connectors, might want to  have a quick lok over it  before installing them,  it's important to get the  wire  installed  the correct amount to get the ends as close as possible.
-jay
