0 Members and 1 Guest are viewing this topic. Read 4886 times.
I would be interested in people's thoughts on scanspeak drivers.
Sorry, I misunderstood!But... if you have the deqx why not be more ambitious?....
I have a pair of custom Selah 2 ways w/ the RAAL 20 tweeter and the Scanspeak Revelator 5.5"midwoofer in a .5 cu ft. cabinet. Very good sound; one of my favorite standmounts ever. The Scanspeak has great tone and blends very well with the RAAL. The RAAL is a bit more transparent than the SS, but you have to be in full audiophile critical mode to pick it up. In normal listening, however, the music just flows very nicely indeed. They are sharply focused and tight but also very easy on the ears. I think the bigger Revelator may not blend as well; I've had the 7" mated to a Fountek and it didn't keep up as well.The Illuminator might be a better match if you need a larger SS woofer. It has a bit sharper focus in the mids than the Revelator.Rick Craig seems to like the Satori with the RAAL as well, for less $.
no need for apologies john, by ambitious do you mean something like 15" open box bass with 200hz tractrix horns with compression drivers and raals. All valve tri amped. Or do you have something else for me to get stuck into.
hi thanks for sharing, do you know the crossover point, the raal 140-15D works very well at the Reccomended 1600hz crossover point.
