New User Question
0 Members and 1 Guest are viewing this topic. Read 1894 times.
Renato6
New User Question
« on: 7 Feb 2014, 09:50 pm »
Hello..
I am a new owner of Bryston and am extremely happy but I have a question. It is probably a newbie question but here goes.
I have a BP-6 connected to my 3B SST. They are running Totem Acoustic Hawks speakers.
I notice that my right speaker sounds louder than my left speaker. I had an older Integrated Luxman amp and did not notice this. I am sure the Bryston gear is just more accurate.
If I switch the Channel gain to 1V it is louder but unbalanced, if I change the switch to 2V gain it is quieter but the speakers sound balanced. Is that normal?
I have tried a few different cables and it is the same.
Is this normal and do I just change the balance dial on my BP-6?
  • The Demo is Everything!
    • http://www.bryston.com
Re: New User Question
« Reply #1 on: 7 Feb 2014, 10:40 pm »
Hello..
Make sure the Stereo /Mono switch on the back of the 3B is in the stereo position.
james
Renato6
« Reply #2 on: 7 Feb 2014, 11:06 pm »
james
Hi James.
I'm sorry but I do not see a stereo/mode switch on the back of my 3B SST. I looked on the actual unit and in the manual.
I see a bridged and individual and that is set as individual.
PRELUDE
« Reply #3 on: 7 Feb 2014, 11:25 pm »
Hi James.
Now, I can be sure that you are new to Bryston world. :lol: :thumb:
bridged = Mono
individual = stereo
Renato6
« Reply #4 on: 7 Feb 2014, 11:27 pm »
bridged = Mono
individual = stereo
Ha yes !!! :lol:
So yes it is in stereo.  :thumb:
PRELUDE
« Reply #5 on: 7 Feb 2014, 11:35 pm »
Ha yes !!! :lol:
OK. :thumb:
Can you hear the difference now or they are balance?
What is your source? CD player, Turntable, Digital player
Renato6
« Reply #6 on: 7 Feb 2014, 11:41 pm »
OK. :thumb:
It is still unbalanced. If I switch to 2V gain, the volume is lower but it seems to balance out the sides.
I am listening to a CD player.
PRELUDE
« Reply #7 on: 8 Feb 2014, 12:04 am »
You have to find out where is the problem first.
switch your speakers not cables and see if your right speaker is still louder.
The V1 or V2 is a option to change the gain and has nothing to do with balance.
Make sure the polarity is correct as well.
Renato6
« Reply #8 on: 8 Feb 2014, 01:34 am »
I switched the speakers and the sound is still louder on the right speaker.
I moved back and the sound did seem to blend together and sound good. I am wondering if I have to get used to stereo sound coming from a higher quality and truer system.
PRELUDE
« Reply #9 on: 8 Feb 2014, 02:41 am »
I knew that magic works in audio but nobody wants to listen to me. :green:
Well, listen and enjoy for few days then let us know.
Just out of curiosity, What was the model number of your luxman?
Renato6
« Reply #10 on: 8 Feb 2014, 04:04 pm »
Yes I guess I experienced the difference of being in the "sweet" spot of stereo that was not as noticeable with my older receiver. It was a Luxman L-210
