Sound quality difference between BDP-1 and BDP-2
0 Members and 1 Guest are viewing this topic. Read 946 times.
miatadan
« on: 2 Feb 2014, 10:03 pm »
Is there any difference between sound quality of BDP-1 and BDP-2 ?
If I have my entire music collection on 1 Intel 240gb SSD, will there be sound difference between the BDP-1 using powered Thermotake BlacX hdd docking station connected to usb input on back of the BDP-1 , compared to putting my Intel SSD into BDP-2 ?
I am using Naim ND5 XS network player to stream internet radio and do not need extra networking features of the BDP-2. Connection between either BDP 1 or 2 is BNC to BNC digital input on Naim ND5 XS.
Dan
unincognito
    • bryston.com
Re: Sound quality difference between BDP-1 and BDP-2
« Reply #1 on: 4 Feb 2014, 02:17 am »
Hi Dan,
Both units contain the same sound hardware and run the same hardware; so they should sound identical.  With that said a number of customers who own/owned a BDP-1 and then Upgraded to the BDP-2 have mentioned the BDP-2 sounding better.  Personally I can't hear the difference.
The external drive enclosure shouldn't effect the audio playback; however if you are worried about the BDP-2 has space and hookups for an internal 2.5" drive and would power said drive with its linear supply.
Cheers
Chris
miatadan
« Reply #2 on: 4 Feb 2014, 03:19 am »
Hi Dan,
Cheers
Chris
Thanks Chris, I agree with you that if it is the same sound hardware, they should sound identical but will think about advantage of internal drive as you say its powered by linear supply.
