Bryston Voltage
0 Members and 1 Guest are viewing this topic. Read 1131 times.
Xinon
Bryston Voltage
« on: 28 Jan 2014, 05:36 pm »
I have a question because as an audiophile it bugs me .
I bought a Bryston 4BSST2 and BP26 from the Norwegian importer .
The 4BSST2 is 240V version and the BP26 is 220V version .
The Voltage in Norway is 230V , so why do we not get the 230V version of  your product?
I know it is probably not harmfull and does not degrade the sound, but it is a little bit annoying .
Xinon
Re: Bryston Voltage
« Reply #1 on: 29 Jan 2014, 01:37 pm »
There is quite a bit of transformer hum from the 4bsst2, but this is maybe normal for Bryston amps?
Or can it be because of wrong voltage ?
I ordered a Bda2 , so I will make sure it is 230V .
Sent a Mail to the importer .
Have a nice day :)
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston Voltage
« Reply #2 on: 29 Jan 2014, 05:22 pm »
Hi Xinon;
Thanks for your question. Norway is one of the countries in Europe that have moved their Voltage up from 220V to 230V.  The Norwegian Bryston importer specifically asked that Bryston amplifiers for sale in Norway be equipped for 230/240 Volts rather than 220/230. Though it is a small difference, it allows the amplifiers to run somewhat cooler and still meet all specifications.  Preamplifiers generate very little heat, so it does not enter into the equation in the same way, and they always are labeled for either 120V or 220V. In the future we will likely change the labeling on the European preamps to read ‘230V’, but the actual power supply will remain the same.
I hope the above is clear and explanatory, but please let me know if you have other questions. Thanks for buying Bryston!
Best regards,
Chris Russell
CEO, Bryston Ltd.
