Bryston B135 preamp out
0 Members and 1 Guest are viewing this topic. Read 935 times.
Rimbaud
« on: 22 Jan 2014, 12:36 am »
I haven't been able to find the answer to this:  With the preamp-out/amp-in slide switches set to "connected," are the RCA preamp outs still active?  I want to run an separate headphone amp while using the B135 volume control.  Any downside to this setup (for instance, voltage-drop with two sets of outputs connected)?
Assuming the outputs stay active, would there be any difference (electrically / sound quality) between this B135 setup and using a set of the RCA preamp outs on a BP17?
I assume that all three preamp outs on the BP17 stay active all the time?  I didn't see anything in the manual about switching outputs.
In my proposed setup, the amp for the speakers would be switched off during headphone listening.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston B135 preamp out
« Reply #1 on: 22 Jan 2014, 02:39 am »
Hi
Yes the pre outs are active as well - no problem in the hookup you want to use.
james
Rimbaud
« Reply #2 on: 22 Jan 2014, 05:01 am »
Ok thanks James.
