Bryston 7B ST's with PSB Stratus Gold i Speakers With add on super tweeter.
0 Members and 1 Guest are viewing this topic. Read 2230 times.
Stereodaddy
Hello friends at Audiocircle, my first post here,
      I have the Bryston 7B St monoblocks hooked up to my PSB stratus Gold I, The speakers Specs are:
      -Sensitivity: 88dB/W/m.
      -4 ohms nominal
I am also soon adding a Sequerra ribbon super tweeter (HF-1) with a sensitivity of 86db, rated at 7 ohms
Now my big question is,
 should I use the Voltage mode, (Series) or the current mode, (parallel)?
Thanks, really appreciate any input.
gdayton
You can certainly try it both ways, but I think you'll get better sound quality and more voltage headroom with series mode. a 7 ohm speaker isn't going to be drawing the extraordinary amount of current that would necessitate parallel.
-Gary
Stereodaddy
Thanks Gary.
  Do I have to turn off the amps before I switch from series to parallel and vice versa?
Paulo
bladesmith
  • water quenching steel since 2001....
    • palmer knives
I can imagine those Stratus Gold I's sound nice, driven with that 7B.. :thumb:
gdayton
Thanks Gary.
Paulo
Hi Paulo,
I certainly recommend it.
-Gary
Stereodaddy
Thanks for the replies. I will try series and parallel modes and find out.
   Yes the Gold i's do sound really nice with the Bryston 7B St's. I love this combination, however I find them just a tad dark, so I am hoping that with the Sequerra super tweeters they will open a up a bit.
   I am also using the BP-26 preamp, and have only good things to say about it.
Paulo
