0 Members and 1 Guest are viewing this topic. Read 13590 times.
Salk Sound and AVA have paired together perfectly for a very long time. More audio shows than I can think of. Just something to consider while making your choice. Have fun,Jerry
I paired Salk ST's with krell kav 400xi integrated, also anthem 225 int.Sounded ok but when I got integrated tube amp - rogue tempest- the speakers sang a whole new tune, and it was a huge change. Added a tube pre amp and even better dynamics.I would vote for tube amp. I have heard AVA and Salk pair great. I never heard them. I know that rogue/ Salk combo is great, and they have 2 new hybrid integrated amps which are very fine- I believe they are sphinx and pharoah. I heard them both at a demo and the even cheaper one was amazing for the price, close to 1 k. I like the fact that the preamp stage is tubed. Nice thing is you only have to deal with 2 tubes in total with those amps.Tomwhat type of wattage on the Rogue? I always liked their sound
Question from a newbie and near-future Salk owner. I have made up my mind to purchase either a pair of HT2-TL's or SS8's (leaning towards the SS8's for obvious reasons), and am trying to decide on an integrated amp that will do justice to either of them. I know, I know...an integrated? you say . Long story short, it is essential for the WAF at the current time. In our current house the speakers will be in a large living room without treatments - no dedicated listening space. So an integrated will be fine for now and I can begin working on separates after the speakers are here. After some research, I am considering the following integrated's:Hegel H300LSA SignaturePass INT-30ABryston B135iKrell S550iW4S STI-500AVA SynergyMcIntosh MA7600I am not so concerned with power- I believe any of these choices could adequately drive the speakers - but am interested in which amp would compliment/elicit the best musicality from the Salk's. Any insights or recommendations, particularly from those with first-hand knowledge, would be greatly appreciated. I would also be interested in any amps not on this list that are worthy of consideration. Thanks in advance for the help.Terry
An AVA Synergy Control Amp (100W ch) would be a great choice for the HT2s.However, the Soundscape Eights will be happier on a much more powerful amplifier, such as the Fet Valve 600R (300W/Ch) that Jim uses at all our joint trade show exhibitions.An integrated power amplifier just will not get the best of of the Soundscapes. They will be starved for power.Regards,Frank Van Alstine
Per your question above, the Synergy 240/3 with the double die option will sound great with the Soundscape 8 speakers, but of course there is still a different between 120W channel and 300W channel with those speakers. We have many users combining the 240/3 with a Fet Valve 400R or 600R on Salk multi-channel systems. They use the 240/3 for the center channel and surrounds and the bigger 400R, 600R or a Synergy 450 for the front main speakers.The S240/3 does have a substantially larger power transformer, higher voltage power supplies, and much greater thermal capacity then the Synergy Control Amplifier and thus does have better authority with difficult loads.Frank Van Alstine
