0 Members and 5 Guests are viewing this topic. Read 44960 times.
The Super 7XRS and Monitor will be offered with either ferrite whizzerless or ferrite whizzer at the same price, and a $300 upcharge per pair for alnico whizzer. The choice must be made at the original purchase of the speakers. The drivers are all OEM and not re-cycled DIY drivers. Omega is not in the DIY business, and not likely to ever be.
So for the benefit of the gentleman who just purchased my DIY Omega 7A drivers (as well as any others out there who currently own them) you are now saying that your latest and greatest Omega speakers are built using this same identical driver, but are now called the RS7A driver. Do I have it right? Very confusing.....gab
I just got off the phone with Louis and found out I had misunderstood him - my fault. The RS7A is a re-badged 7A. Same speaker. The DIY 7F, both whizzered and whizzerless ARE different drivers than the RS7 both whizzered and whizzerless. They always have been different right from the beginning.There is no need to worry that you have an inferior product if you have DIY drivers, because you don't. They're just different. In all my years dealing with Louis, he has never made a dud. Never.The latest and greatest from Louis will be 12" subwoofers and his Paramount line. He is one of the very few speaker manufacturers that has his own drivers.
Rob, Sorry to belabor this. So, it seems I do have the RS7A, but I am unclear about the F I have that came with the Super 7. Is it RS7F as the label on the cab says or 7F as Louis and I referred to it during the order? Either way is ok, I'd just like to know what I have.Thanks.......Peter
You have an RS7V whizzerless. "V" stands for vintage.
I like EL34s... I have a bunch of them. I would go with NOS, new aren't even close imo... I don't have any high $$$ ones but Winged C and Mullard xf3s are great. The new GL kt77 is good too but probably not nearly as reliable.Hoping to pick up the Sylvania big bottles soon too.In the next 6 months or so I will be putting an EL34 SET amp on the market with an all-film-cap power supply, copper foil coupling caps and 4 separate high voltage power supplies. It is intended to be a big step up from Decware and the like but still come in reasonably priced. Going for about double the price of Decware's EL34 SET...
The back of your speakers say 95dB.
Thank you.... duh!Though that's for the RS7V. Still curious about the RS7A. Same or lower?Thx .......
The RS7A is 93dB. It is also a completely different driver than the 6.5" HempCone alnico driver.
Hi pstrisikWhen I bought my alnicos Louis said they would be a conservative 93db sensitive, and also very effiecient, which also is a factor for how they play- not sure how that is measured though, but I understood that to be a relevant factor for SPL amd how they would perform.
