0 Members and 1 Guest are viewing this topic. Read 45741 times.
Hi all,I have on order a handmade by Dennis Had 12wpc single ended KT150 based amp. (Dennis Had is the designer of the Cary tube products. I have his SLP-05 preamp and absolutely love it. He also designed the Cary CAD-805 series amps.)Dennis claims it will power most cone based speakers fine. I'm skeptical though I will give it a shot. I have restored AR2ax'. They are at 87db / 8 ohms. AR says minimum 20watts - this was stated around 1970. Great experiment and experience in any case.So, Omegas may be in my future! I have no experience with single ended amps or full range drivers, but I like what I am reading. And looking around at the options, Omegas draw me the most. Oh... I'm running a Conrad-Johnson Premier 11A (70wpc p-p amp) between the Cary SLP-05 and the AR2ax'.
Hi pstrisik,Many thanks for your post and kind words. I have seen but not heard the new gear from Dennis Had. It looks great and I'm sure the amps sound great too. Years ago I had an old SLA70 that I liked and had a 300 SEI for a while too.I hope that single drivers get more popular and looks like more and more low powered amps are coming out. Now with the RS5's it's a great time to try the 3 series lineup. Many thanks FireGuy and a good 2 watts is a great way to get started.Thanks again,Louis
pstrisik, I have an EL34 SET that needs to be rebuilt at some point.... going from a modded, burnt PCB to ptp wiring since my SET has no driver stage, my preamp has enough gain and can drive the EL34s directly.I am considering rebuilding the amp with kt150s instead of EL34s, have you heard both by any chance?
Louis tried for a long time to develop a suitable AlNiCo based small driver, but finally gave up. AlNiCo has higher flux density and reportedly a warmer sound.From my readings (and experience beyond his current drivers) the smaller drivers are faster and would integrate better with the proper (fast) subwoofers. Specifications can't tell the whole story in life. Common sense says bigger drivers will push more air and provide more feel/substance of the bass. So with your subs, the RS5 in one of the smaller cabinets would be the direction I'd go.And frankly whizzer cones confuse me (I've yet to get a good explanation as to what is going on there). I have 8 inch AlNiCo full range drivers (Fostex F200A, 30 - 20,000 Hz, 8 ohms, 89 dB/w/m, about $425 each) that have no whizzer, which means for better or worse they beam above roughly 4,000 Hz. I wanted coherence across the entire frequency range, but if doing it again would look into a swam of subs (search Audio Circle, read Floyd E. Toole's 'Sound Reproduction') with the RS5 in one of the smaller cabinets.Fairly big room, how loud do you listen? (Like any small extended range driver the RS5 has limited excursion/output, but the subs would help.)
There is a 7" version of the RS5 driver, the ferrite motor has no whizzer but the alnico does. A whizzer is a mechanical crossover.... Louis would know a lot more about the pros/cons and design considerations for using a whizzer or not...
...you may already know this, but every 3db in volume is a doubling of power. So coming from 87 db - and depending on which model Omega you choose - you will likely have the equivalent of 4x or more in perceived power (as an example, 87 to 93db is 2x2 = 4 times.) So a 10 watt amp on your current speakers would sound likes pumping about 40 watts or more in volume on Omega from the same amp. Or in reverse, 10 watts on Omega (assuming 93 db) will be about as loud as 40 watts on the 87db speakers. I hope that makes sense. Kent
It might not be on the website yet, but there was a pic posted of a 7" in an XRS type cabinet so I assume it is orderable.
http://www.audiocircle.com/index.php?topic=121531.0
