Super 7 XRS
happyrabbit
Super 7 XRS
« on: 24 Nov 2013, 01:14 am »
Let me introduce the SUPER 7 XRS IN EBONY.    :green:  :green:  :green:
I should have them very soon.    I will report back once setup.
Dwight
« Last Edit: 24 Nov 2013, 02:21 pm by happyrabbit »
DaveC113
  • ZenWaveAudio.com
Re: Super 7 XRS
« Reply #1 on: 24 Nov 2013, 01:20 am »
Nice! A pair of those may be in my future as well...  :)
KnyazHM
Re: Super 7 XRS
« Reply #2 on: 24 Nov 2013, 11:19 am »
What is the frequency range of these speakers? They are better than whizzer version?
Louis O
Re: Super 7 XRS
« Reply #3 on: 24 Nov 2013, 04:21 pm »
Hi happyrabbit,
Thanks and should be getting them out tomorrow.
I will be posting much more on the Super 7 series that will include a monitor as well.
The speakers pictured are finished in EKO Ebony and the look is great. I have spent a lot of time getting my photography skill a bit better too.
Hi DaveC113,
Great to hear and very happy with the new range. I will get more info and more pictures up very soon.
Hi KnyazHM,
They will go down into the lower 40's and will go up to 18Khz. The SPL is 95dB.
Thanks again,
Louis
Moot
Re: Super 7 XRS
« Reply #4 on: 26 Nov 2013, 08:58 pm »
Those are gorgeous!
Congratulations!
Louis O
Re: Super 7 XRS
« Reply #5 on: 28 Nov 2013, 08:53 am »
Hi Moot,
Many thanks and I will post more pictures in other finishes soon,
Louis
happyrabbit
Re: Super 7 XRS
« Reply #6 on: 2 Dec 2013, 12:46 pm »
Dwight
DaveC113
  • ZenWaveAudio.com
Re: Super 7 XRS
« Reply #7 on: 2 Dec 2013, 04:43 pm »
Good looking speakers Dwight.  :thumb:   I have the Super 3 XRS as well. Can you compare the sound of the two for us?
Also, I was considering trying to use the Super 3s as an "ambiance" speaker, stealing the idea from the Audiokenisis LCS that was at RMAF this year.  :)   Basically, you would put the Super 3s on their backs facing up behind the 7s. The sound from the 3s will bounce off the ceiling like a bipole... if it works it will make the sweet spot wider and the soundstage deeper.
Louis O
Re: Super 7 XRS
« Reply #8 on: 4 Dec 2013, 12:56 am »
Hi DaveC113,
I have done this a bunch of times and the sound is great. I will be offering these too. It will be part of the multipoint. It's an omni of sorts.
The custom section will have quite a few larger projects. My latest 8" driver is on the bench now. This is the 3rd prototype.
Hi Dwight,
Nice to see them side by side and the 7's are so much deeper.
Louis
sugbob21
Re: Super 7 XRS
« Reply #9 on: 4 Dec 2013, 05:50 pm »
Hi Louis !
Is there any benefit to putting the super 7 driver into the super 6 monitor  ?  Can it even be done ?
Bob
JeffB
Re: Super 7 XRS
« Reply #10 on: 4 Dec 2013, 10:32 pm »
What size is the driver?  The name makes me want to guess 7", but aren't the 3-series a 4.5".
sugbob21
Re: Super 7 XRS
« Reply #11 on: 5 Dec 2013, 12:56 pm »
i assumed it was 7" also. I was just thinking  if it would fit i would get a better bottom end and slightly higher  db.  Not sure if it will work though.
Louis O
Re: Super 7 XRS
« Reply #12 on: 9 Dec 2013, 11:54 pm »
Hi sugbob21
Thanks and it can be done easy.
Actually the new seven series standmount is similar the the 6 series stand mount right now. I have updated the 6 series and the monitor is getting a little bit larger. I'll have pictures up soon too. I have a great set in Zebrawood just about done.
Hi JeffB,
The name comes from the driver frame size in regards to the 7's. The frame is actually 7 1/8 inch. You are right about the 3 series and the they are 4.5". I just like the number 3.
Hi sugbob21,
Actually a cabinet increase in volume will do the trick.
Louis
happyrabbit
Re: Super 7 XRS
« Reply #13 on: 15 Dec 2013, 02:42 am »
A Phone call to Louis will lighten your back account  :o
I will report back after I hit the 100hr mark....
Dwight
DaveC113
  • ZenWaveAudio.com
Re: Super 7 XRS
« Reply #14 on: 15 Dec 2013, 03:08 am »
New 8" Alnicos?  :thumb:
happyrabbit
Re: Super 7 XRS
« Reply #15 on: 15 Dec 2013, 07:46 pm »
7'' Alnicos
DaveC113
  • ZenWaveAudio.com
Re: Super 7 XRS
« Reply #16 on: 15 Dec 2013, 07:47 pm »
OK, I thought the 7s didn't have whizzers but I guess the Alnicos do? Looking forward to hearing your impressions...  :)
Louis O
Re: Super 7 XRS
« Reply #17 on: 15 Dec 2013, 07:56 pm »
Hi happyrabbit,
Nice alnico's
Hi DaveC113,
Alnico have the whizzers.
Thanks again,
Louis
jorgen
Re: Super 7 XRS
« Reply #18 on: 16 Dec 2013, 04:14 pm »
Hi everyone
had to create a profile. I ve been emailing with Louis, long story short, 35" x11x8 floorstanders with 7" alnicos. High WAF with bubinga finish i hope.
« Last Edit: 18 Dec 2013, 01:55 pm by jorgen »
opnly bafld
Re: Super 7 XRS
« Reply #19 on: 30 Dec 2013, 11:08 pm »
Hi everyone
Jorgen,
Sorry I missed your post, excellent choice!  :thumb:
Lin (on your amp maker forum)
