0 Members and 1 Guest are viewing this topic. Read 24029 times.
Neo, I'm curious, why do you think the designers of that arm found it desirable to have a low effective mass in the vertical direction?
I seemed to remember the guy from Agon (link on page 1) saying something about antiskate and skips. "The only slightly negative thing about it, is that it increases the anti-skating force, so you have to cut that back a little, and if you have some marginal scratches that might skip, they are more likely to skip with this mod, due to the resistance to sideways movement provided by the outriggers. I had this happen once last night, but I didn't consider it a problem."I think by "skips" he means getting hung up in a groove. "due to the resistance to sideways movement provided by the outriggers" would imply that.So, is this increased lateral eff mass or damping, or both? I don't think they're exactly the same. Arm bearings not up to it? We don't really know what he has except he alluded to a Rega style bearing housing and he's using a 103. The Ortofon cart that David mentioned (somewhere) with asymmetrical damping, is a DJ cart tracking at 4g. I don't think this is used in their regular carts.Even if this works great on an SME IV, it might not be so great on another arm? I'm not a scientist or a ME, but I don't like it when it skips or gets hung up. neo
