0 Members and 1 Guest are viewing this topic. Read 24025 times.
"Cantilever deflection can reach more than a few degrees by side thrusts so that tracking angle error distortion is increased. To avoid such occurrence, the compliance should be kept not excessively high, and linear tracking arm (not swinging but linear shifting) is preferable".
I've been told by someone close to him that Mike Fremer has a DP8 in his line up for a review. It's been a while since a mag reviewed a Morch arm, so this could be interesting to compare it to the other big boys that appear there frequently.(Note: I have a DP6)
The Rega mod using the fishing weights over the pivot nuts...It seems to me that it may have an aspect of lateral stability but part of its gain may be simply due to the use of a highly effective damping material (Lead) near a cause of vibration (bearings) - it is not clear that the particular implementation discussed in the Agon thread is in fact a lateral mass mod rather than a high frequency bearing chatter mod.
The VPI is a unipivot arm (not sure the Moerch, etc).
