0 Members and 1 Guest are viewing this topic. Read 10783 times.
I've also been curious about Decware amps. Do these fit the sort of specifications that the original poster is interested in?http://www.decware.com/newsite/tubes.htmlIS there anyone out there familiar with these amps? Can you compare to Music Reference or some of the other amps being discussed here?
I've got a Line Magnetic Audio integrated tube amp that I like alot. Here http://donbetteraudio.com/products/amplifiers/ at top of page.I did a review of this amp here- http://www.audiocircle.com/index.php?topic=104440.0They also have other models and some SET amps too. FWIW
Martyn I am not sure of the current status but I know Roger (Music Reference) has discussed amp kits in the past. Maybe you could talk to him and get an idea if he has anything available or if there is something in the works.
As far as tube rolling is concerned, the amps I recommended will all sound great with their stock tubes. You can plug and play right out of the box and enjoy yourself. Rolling can be expensive but for tubeaholics like myself it's really fun and changes up things nicely. It's your choice.As for your goal of 'true and faithful reproduction' I think that's a pie-in-the-sky goal to shoot for. If you think about it, you have no control over many aspects of what is true and faithful. What's on the CD and what happened in the studio are very likely two totally different events. There have been many 'skews' to the original sound between mic and laser lens. Additionally, we pick our other components, especially speakers, based on our own ideals of sound which may or may not gel with the original event. If you want to stick with faithful reproduction of what is on the CD (or whatever medium you choose) then there are many sterile ss components to choose from. But if you really want to enjoy what you hear then tubes are the way to go in my opinion.Back to the Rogue and Music Reference amps; neither are euphoric tube amps. They are both about as neutral as tubes can possibly get...which I think is your goal. But they still contain tube magic which some might say goes against true and faithful reproduction.
Well stated indeed - thank you both for your thoughtful comments.I'm less interested in reproducing a performance and more interested in reproducing the way an instrument actually sounds. I find that a good recording and decent equipment typically produces a much better result than the actual concert hall. The concert involves too many compromises, although these tend to be off-set by the emotion of the event. Many of those compromises can be eliminated in my living room, but if a harp sounds like a dulcimer, the emotion will be gone. I agree that speakers are the most important link in the chain. I haven't quite achieved "true and faithful reproduction" yet, but I'm getting closer!
Ericus, I think you're way ahead of me. I just want a violin to sound like a violin...I'll worry about who's playing it later!
