0 Members and 1 Guest are viewing this topic. Read 10791 times.
Check the input sensitivity and make sure your source has enough output to drive the amp to levels you desire with your speakers. I have noticed the Music Reference will do well in this situation...
I've always had issues with the low end of most tube amps, until I bought NOS Valves VRD Mono Amps. They are end all amps and have ran circles around everything I have ever tried.
The MR RM-10 Mk II is the way to go. It's perfect for passive pre's or a source w/a volume control. I've owned a lot more expensive SS (Pass, Classe, Conrad Johnson) & tube amps (ARC, Cary, Rogue, Conrad Johnson) & this is my keeper
...If you can swing it, I'd recommend getting the new Rogue ST-100 amp as it trumps both the Tempest and Cronus and has solid-state-like command of the lo-end.
if I had your building / engineers skills I'd love to build one of the Audio Note EL34 kits - the monos for example would be nice match for average efficiency speakers and not too big a room.http://www.ankaudiokits.com/index.html#Martyn haven't talked in long time - good to see you still have your AKSA amp - still envious.David in Victoria
