0 Members and 1 Guest are viewing this topic. Read 13586 times.
I'd appreciate any advice you can offer on what I'd need to measure my room.
What specifcally should I set for input and output on the soundcard?
I owned the stratas in the past... first of all... is that measurement with the subs on? You need to take your first measurement with the subs off. Also, do one speaker at a time and we need to see both speakers measurements.
Thanks. The posted plot was the left speaker only with amp turned on. I will turn it off and take another measurement. I think when the amp is turned off on the mini the phase, level and crossover don't matter but I will go ahead and leave phase as 0, level at 9AM, and crossover at 30 for comparison sake.
interesting... ok, so based on what you can see here, what do you think? If those were my measurements, id be starting with the sub as low (30-40hz) as it can go on the crossover and try another reading with the volume just barely kicking on... Take another measurement and see what happens.
Did you calibrate your mic yet. ?https://www.youtube.com/watch?v=21wUsNfF2Lw&feature=youtube_gdata_player
