0 Members and 1 Guest are viewing this topic. Read 13640 times.
Measuring each individually is the way to do it to look at impulse response and also to identify any issues specific to one side or the other due to asymmetry, differing reflection surfaces, etc. But in the end you also need to measure with both channels as that's how you listen. If you have no problems with each individually but DO have a problem when both are going, it identifies an interaction between the 2 speakers that should be addressed.
No clue about 200. I've new to measuring and am not done with more testing. Also have not tweaked the amp settings on the minis so there could be more improvements possible.
Have any of you guys used the Behringer UCA222 as a sound card for REW? It has both L/R RCA inputs and outputs.
There is a bunch of guidance on Home Theater Shack under the REW Forum:http://www.hometheatershack.com/forums/rew-forum/
Here is a video we make on REW.http://www.gikacoustics.com/room-eq-wizard-tutorial/
