WTB speaker stands… which?
0 Members and 1 Guest are viewing this topic. Read 2896 times.
arthur
« on: 20 Nov 2013, 08:36 pm »
Need a sturdy 24" stand for my new Fritz rev 5s. Preferably Targets or something as good.
Speaker size
around
Base 8x10
40lb
I'm in Los Angeles
Thank you!
« Last Edit: 21 Nov 2013, 10:38 pm by arthur »
rollo
  • Rollo Audio Consulting -
Re: WTB speaker stands
« Reply #1 on: 21 Nov 2013, 04:42 pm »
   Congrats on a fine speaker. Check IMO the bargin of all times. B&W stands at Best Buy. We use them at the shows. Very good stand.
charles
arthur
Re: WTB speaker stands... which?
« Reply #2 on: 21 Nov 2013, 07:04 pm »
Thank you. Ya the speakers are aaaaamazing!!! I can't wait to set them up properly to really see what they can do. Even now, sitting on wobbly $10 JVC speakers, they sound much better than expected. I'll try to write a short review once I'm done setting them up and spend some time positioning them.
Do you mean these stands?
http://m.bestbuy.com/m/e/product/detail.jsp?skuId=1502082&pid=1218264251967&ep=pv-3.3.1,rc-av,av-0,rk-1
I also found the following ones.
http://www.dynamichomedecor.com/merchant.mvc?Screen=PROD&Product_Code=VTI-VSQ-STANDS&Store_Code=DHD
http://m.wayfair.com/products/VI1172
http://m.wayfair.com/products/TDI1075
http://www.needledoctor.com/Pangea-DS-300-Speaker-Stands
http://www.audioadvisor.com/mobile/Pangea-Audio-LS200-Speaker-Stand/productinfo/PGLS200/
http://www.parts-express.com/dayton-audio-ssmb24-24-speaker-stand-pair-square-steel-base--240-750
But the ones that seem most promising are these - but they are out of stock for 24"
http://www.audioadvisor.com/mobile/Pangea-Audio-DS300-Heavy-Duty-Speaker-Stand/productinfo/PGDS300/
Any thoughts on which ones might work better for me?
Thank you!
srb
« Reply #3 on: 21 Nov 2013, 07:30 pm »
The farther out the supports are to the edges of the base, the more stable they will be, with the Sound Anchor 4-post type stands being the most stable.  Of the ones you've listed I think the Pangea might have the most stability.  Although you note that the Pangea DS300 is out of stock at Audio Advisor, you also have a link to the same stands at Needle Doctor where they appear to be in stock at the same price ($169 +  free shipping).
It would be nice to have a top plate that is also 8" x 10", but the Pangea is not too bad at 7.5" x 7.5".  Because speakers are front heavy due to the drivers, in this case I would set them on the top plate flush with the front and let the 2.5" depth hang over the rear.
« Last Edit: 22 Nov 2013, 12:47 am by srb »
arthur
Re: WTB speaker stands… which?
« Reply #4 on: 21 Nov 2013, 10:44 pm »
actually the exact measurements of the speaker is 7.5x9.5 so 7.5 so the sides will be perfect but the back will hang out 2" if i go with the Pangea DS300. I don't think I'm likely to find anything better than these in these price ranges right?
… unless i was in Chicago :(
http://www.usaudiomart.com/details/649062987-speaker_stands/
That's a great deal on those sound anchors. Too bad i don't know anyone in those parts.
If you are reading this and you are anywhere near Chicago, don't miss out on these.
klamka
« Reply #5 on: 22 Nov 2013, 03:36 pm »
I have TARGET HR60
 which are too tall for my speakers .I need something in a range of 16-19 .Excellent condition with boxes and all accessories but shipping from Chicago would be rather high. I'm back home on Sunday .Rgrds, k
arthur
« Reply #6 on: 22 Nov 2013, 05:00 pm »
Chicago is turning out to be quite the hotbed for quality speaker stands. Anyone in LA?
