Help with a sub connection (edit) fixed
0 Members and 1 Guest are viewing this topic. Read 1096 times.
charmerci
« on: 7 Nov 2013, 08:37 pm »
I just got a used Pioneer AVR. I was using a Denon receiver where I connected the RCA L/R pre-outs to the inputs on the sub. No problems there.
In the back there is one SW pre-out, so I ran to the local Rat Shack and bought a 2 to 1 adaptor. Quick set up says "sub detected." I go through and select 4.1 speakers then it asks me to confirm. Nothing. Sub is on. On the front, there is "sub ch mode" button. I toggle thru on/auto/off. Nothing. Also on the back, there are Pre-outs for the surrounds/center/front speakers. I plug it in there without any adaptor, redo the set up procedure. Nothing.
Any suggestions? Thanks.
« Last Edit: 7 Nov 2013, 10:54 pm by charmerci »
Re: Help with a sub connection
« Reply #1 on: 7 Nov 2013, 08:48 pm »
How is the sub set up? If you were running from preouts before your sub was doing the crossover. The sub out will be crossed over signal based on a value in the settings. Could be the signal from your AVR is below the set crossover on the sub.
randytsuch
« Reply #2 on: 7 Nov 2013, 08:57 pm »
Is there a small speaker setting?
I think I remember on some receivers you need to set this to get a sub output.
charmerci
« Reply #3 on: 7 Nov 2013, 08:59 pm »
If I understand correctly, I've turned the low pass filter on the sub from 80hz > 160 hz. Still nothing.
Went through the manual, looked up SW set up and went through that too. Still nothing. Maybe the sub channel is broken?
charmerci
« Reply #4 on: 7 Nov 2013, 09:43 pm »
OK, now something has changed.
It works with my computer DAC into the DVD/LD input but not my CD player in the CD input!!!
It only works in the DVD input.  :duh:
Another bizarre thing - when I toggle thru the speakers, the sub works with both sets and A but not the B set.  :scratch:
« Reply #5 on: 7 Nov 2013, 09:57 pm »
Are the output settings different between the two inputs? By output settings, I mean Stereo, Direct or Dolby.
charmerci
« Reply #6 on: 7 Nov 2013, 10:01 pm »
It works on Direct, Stereo and Surround modes.
So I guess I had to set it via the remote.
It all works now outside of using only the B set of speakers - which is what confused me for the latter part because that's what I was listening/testing with.
