0 Members and 1 Guest are viewing this topic. Read 33533 times.
Hello Guy 13,I have used quite a few 12AU7 and 12AU7 equivalent tube types, so I will comment on that particular tube: Right now, my very favorite 12AU7 is the CBS Backplate 5963. I acquired two full sleeves of them on eBay for 35 dollars total. I think the tube Gods were smiling down on me that day. Well, either that or it was my turn to finally get a good deal. Other 12AU7 types that I enjoy very much are JAN G.E. 6189W, BRIMAR CV4003 (way overpriced), and G.E. Five Star ***** 5963. I am not a big fan of RFT 12AU7, as I find them way too bright for my tastes. I guess if your particular audio component needs some illumination, then RFT might be a good choice. I have many others to try, including the usual American standard 12AU7 types, and some Euro ECC82s, but it is a bit of a pain to remove all the little screws in the top cover of my DAC just to roll tubes. When I put in a set of 12AU7s I usually turn them on and enjoy them for 6 months to two years before I try another flavor. The tubes are left continuously powered up because that's just the way it is with my DAC. Not that it matters, just sayin' FWIW.I have no affiliation with Brent Jesse, but he has a lot to say about 12AU7s and maybe he can help you sort some things out like tube number designation. Scroll down near the bottom of this page to read about equivalent 12AU7 types : http://www.audiotubes.com/12au7.htmLast but not least, there are some people who just don't like the 12AU7. If you don't like the 12AU7 don't blame it on the tube, blame it on the device using that tube. It is the overall design implementation and quality of that audio component that makes a 12AU7 sound good, not the other way around. In my opinion and no hard feelings of course.
Input from users at the BH forum: http://www.bottlehead.com/smf/index.php/topic,663.0.htmlIf you spend some time on the site, you will find the the HD650's are likely the most favored match to the Crack!I use AKG 240 Sextett and K140-4 600ohm headphones on my Crack with a Chatham or RCA JAN 6AS7G. I find them warmer and with more accurate timbre than the 6080. I have CEI & RCA 6080's, they are a bit more detailed, but with the vintage AKG's I prefer the 6AS7. The "Holy Grail" is the Tungsol 5998, but more highly regarded for lower impedance cans.I also have AKG 702's. Although lower impedance, 62ohm, (my Crack is optimized for 600 ohm's) they sound good with the Crack. I could optimize the Crack for them by increasing the output capacitance. That is the joy of the Crack, you can easily customize it to your heart's content.BTW, I replaced the 12AU7 on mine with a 7N7, ( the Loctal equivalent to a 6SN7 octal). The 12AU7 is not one of my favorite audio tubes. IMO, the 7N7/6SN7's are a more linear, much better sounding tubes in almost every aspect. That being said, the amp sounds very good with a quality old stock 12AU7. My favorites were from Mullard and blackplate RCA.Cheers,Geary
If you go on headfi.com, there is a thread about the Crack amplifier.You will find many posts about tube rolling. Also...if you look on theBottlehead forum, there is a whole section on modifications and upgradesthat people have done to their amps. This includes tube rolling.Let the fun begin!Hibuck...
Guy,I would not want to ruin the sound of my amp just to reduce the heat from one tube. That's all I meant to say. Maybe I am wrong. Buy one and tell us how much better or worse it is.
