Anyone running a dedicated mono cartridge?
0 Members and 1 Guest are viewing this topic. Read 1128 times.
J-Pak
« on: 4 Oct 2013, 03:50 pm »
I have a friend with a Miyajima Premium Be mono and with a good vintage mono LP it can send shivers down my spine. A few days ago I took a 6-eye mono first pressing of Miles Davis Round About Midnight to do a comparison with the recent Mofi reissue. The first pressing with the mono cartridge was incredible; the reissue just couldn't compare in tonal complexity and realism. That was the best I've heard that record sound, and I'm really familiar with its sound.
So I'm curious if anyone else here is using a mono cartridge? I wish I could, but my Spacedeck can only accommodate a single tonearm.
rajacat
  • Washington State
Re: Anyone running a dedicated mono cartridge?
« Reply #1 on: 4 Oct 2013, 05:30 pm »
   Member jsaliga has a high end mono setup.
...Roy
neobop
  • BIRD LIVES
« Reply #2 on: 6 Oct 2013, 04:15 pm »
There was a thread about mono carts recently.
http://www.audiocircle.com/index.php?topic=118709.0
neo
jazdoc
« Reply #3 on: 8 Oct 2013, 08:09 pm »
I'm using a Miyajima Premium BE on a Durand Talea tonearm wired for mono which feeds a dedicated mono phono stage input.  If you are into jazz and early pop; mono is the way to go.
