0 Members and 1 Guest are viewing this topic. Read 5101 times.
First of all, The Chair Guy is would be happy to acknowledge your thanks, but you may not know that he suddenly passed away a month or so ago.
05-23-09: EldartfordA stereo cartridge is sensitive to vertical modulation of the groove. A mono record has only horizontal groove modulation, and whatever vertical movement occurs (and this includes turntable rumble) is pure noise, and you don't want it. It is essential to remove sensitivity to vertical modulation by jumpering the two channels together, or using the MONO switch on your preamp (if it has one).
..., it seemed that the best mono carts were those that picked up nothing from the vertical plane.
From a purist point of view I think you're right. Vertical noise would be cancelled as well, except maybe if it was equal in both channels. If that were the case, it would probably be present in the horizontal but maybe less so?I have a number of modern mono pressings that should benefit from strapping, with I suspect little negative consequence compared to a true mono cart. On the other hand a noisy vintage record might be much better with a true mono cart. neo
mono cart that I have
