Betsyk phase plugs
0 Members and 1 Guest are viewing this topic. Read 3427 times.
opa1
  • ALEPH J, ALPAIR 10P CGR, Lii Audio F-15 OB's.
Betsyk phase plugs
« on: 28 Sep 2013, 04:56 pm »
Has anyone tried phase plugs on their betsyk's? I have a set in MLTL's. They sound great. Just wondering if the plugs would be a good move.
Mark
ejfud
Re: Betsyk phase plugs
« Reply #1 on: 28 Sep 2013, 10:52 pm »
I have them in my original Betsy's and like them a lot.
opa1
« Reply #2 on: 28 Sep 2013, 11:42 pm »
Hey ejfud, Where did you find them? Or did you make them?
Mark
ejfud
« Reply #3 on: 29 Sep 2013, 12:53 am »
They came with a one homemade pair, and I just did a few others from doweling to play with and see what difference I could hear.
opa1
« Reply #4 on: 29 Sep 2013, 02:33 am »
Looks like a 3/4" dowel might work. I'll see if I can make a set.
Mark
ejfud
« Reply #5 on: 29 Sep 2013, 03:42 am »
That sounds right. Here's a picture of the Betsy's.
http://www.audiocircle.com/image.php?id=60733
opa1
« Reply #6 on: 29 Sep 2013, 04:36 am »
WOW! That's some nice woodworking on the enclosure.  I'll chuck up some dowels in the lathe and see how they come out.
Mark
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #7 on: 30 Sep 2013, 06:50 am »
Just under 25mm diameter is required. I still have some.
dave
opa1
« Reply #8 on: 30 Sep 2013, 02:41 pm »
Have you tried any of your upgrades on the Betsyk's?  I've read a lot of your posts at DIY.  I remember reading about the plugs.
Mark
planet10
  • Frugal-phile (tm)
    • planet10-hifi
« Reply #9 on: 30 Sep 2013, 06:20 pm »
I have 2 of the 1st batch of Betsy which i understand had a manufacturing issue with the cone material. I gave one set the full treatment which worked well.
dave
opa1
« Reply #10 on: 30 Sep 2013, 06:46 pm »
They sure look better with the upgrades.  :thumb: I have these in a pair of MLTL's that GM designed for me. I'm doing a total system upgrade. So I figured the speakers are first. I'll go to your site and check out the plugs.
Mark
