two NC400 driven by one SMPS600?
0 Members and 1 Guest are viewing this topic. Read 3733 times.
rs3412
« on: 25 Sep 2013, 09:12 pm »
Hello everyone!
I am fascinated by all the comments on Hypex NCore from its users and about to build one for myself too.
I am just wondering, whether it is possible to use one SMPS600 to drive a pair of NC400?
If so, how to connect? (with the cables provided by Hypex)
Many thanks!  :green:
revelinhifi
Re: two NC400 driven by one SMPS600?
« Reply #1 on: 26 Sep 2013, 10:16 am »
Hi
I use 1 SMPS600 powering two NC400
in your order you get a single ended and dual ended power cable connector set, all I did was cut the dual ended power cable connector and soldered the single ended to the split in two dual ended cable effectively making a Y cable connector.
Ah here is a picture of the Y cable see in the post below
http://www.audiocircle.com/index.php?topic=118868.0
Cheers
John
Julf
  • Grumpy second cousin of Mark V Shaney
« Reply #2 on: 26 Sep 2013, 10:32 am »
Yes, that's what I did too. I have 2 x 4 nc400's, with each pair sharing a SMPS600 (so 8 nc400's, 4 SMPS600's).
jtwrace
    • TIPP YouTube Channel
« Reply #3 on: 26 Sep 2013, 11:09 am »
You should add your system to your page.
http://www.audiocircle.com/index.php?action=systems
Julf
« Reply #4 on: 26 Sep 2013, 12:38 pm »
I will, as soon as I finish the new active crossover and clear up the cable mess... Just need a round tuit...
rs3412
« Reply #5 on: 26 Sep 2013, 02:53 pm »
You made my day!  :thumb: :thumb:
Hi
Cheers
John
