J-River and Synology issues
0 Members and 1 Guest are viewing this topic. Read 4924 times.
sts9fan
« on: 17 Sep 2013, 04:06 pm »
I have been experiencing some minor annoyances with jriver and my synology NAS. I am sure there are better forums to ask but you guys know your stuff.
I am finding that JRiver is losing the connection to the library everytime I reboot my computer.
I am also having issues with the synology not staying mapped. It was showing up under network as DATASERVER which is what I named it. Now it's not there. I can use the synology assistant to map it but it then shows up under computer. Then when I reboot I need to remap. I know these are Windows 8 questions but I hope someone here will be kind enough to help.
Syrah
Re: J-River and Synology issues
« Reply #1 on: 17 Sep 2013, 04:14 pm »
Uh oh.  I use JRiver and I just ordered a DS1513+.
srb
« Reply #2 on: 17 Sep 2013, 04:17 pm »
Windows 7 was a little sketchy about Network Discovery, and I'm guessing Windows 8 may be also.  If you're not already using static IP addressing, consider assigning a static IP address to the Synology and using the IP address in the network path rather than than the UNC "DATASERVER" server name.
sts9fan
« Reply #3 on: 17 Sep 2013, 04:21 pm »
Ok. I will google how to do that. Would that be in Control Panel or the synology software?
srb
« Reply #4 on: 17 Sep 2013, 04:36 pm »
Setting a static IP address for the Synology NAS would be done through the Synology DSM Web Interface in Control Panel > Network > Network Interface tab.  The IP address assigned would need to be in your local network IP range, likely 192.168.x.x with Subnet Mask 255.255.255.0
I assume your router is the DHCP server for your network, so you would want to set that IP address (and any other static IP addresses) as a Reserved address excluded from the pool of automatically assigned IP addresses.  It depends on your particular router, but that is often found under LAN Setup > DHCP in your router's web configuration page.
jtwrace
    • TIPP YouTube Channel
« Reply #5 on: 17 Sep 2013, 05:12 pm »
On my Mac one needs to have the Synology auto mount.  I also have JRiver auto mount too.  I'm sure there is a way to do it in Windows but I have no idea.
Static IP really is a must as srb has pointed out.
jtwrace
sts9fan
« Reply #7 on: 17 Sep 2013, 08:44 pm »
Mapping a drive is not an issue.
jtwrace
« Reply #8 on: 17 Sep 2013, 09:08 pm »
Never mind then
sts9fan
« Reply #9 on: 17 Sep 2013, 10:30 pm »
Setting the IP address static in the synology web interface fixed it!
Syrah
« Reply #10 on: 13 Oct 2013, 07:26 pm »
Hi guys.  Big issues here too.  I have jriver 19 and a synology 1513.  I managed to plug my usb drive into the synology and transfer files.  I can see the transfered files on the synology on File Station.
Now when i go to jriver in Devices and Drivers, click on Network, it seems to have created at CAPSv3 directory but it wont show Diskstation, and it doesnt access any files when i click on CAPSv3.
Any advice?
jtwrace
« Reply #11 on: 13 Oct 2013, 07:32 pm »
Did you map the Synology as a drive?
Syrah
« Reply #12 on: 13 Oct 2013, 07:36 pm »
How do i do that?
Thanks.
sts9fan
« Reply #13 on: 13 Oct 2013, 07:41 pm »
You new to use the Synology manager software. Then push the map button. Super easy.
Syrah
« Reply #14 on: 13 Oct 2013, 07:47 pm »
You guys are awesome!
I spent 4 hours ripping my hair out before spending 10 minutes here and solving it.
Thank you!
