shengya s10 tube cdp - the review-
0 Members and 1 Guest are viewing this topic. Read 19595 times.
F-100
« Reply #20 on: 22 Oct 2004, 04:17 am »
I know you're not suggesting but I'm just curious about this Kavent player. Any review??
guest1632
  • Guest
« Reply #21 on: 22 Oct 2004, 04:22 am »
Quote from: F-100
rosconey
« Reply #22 on: 22 Oct 2004, 07:53 am »
shengya is 350+125 shipping and tax if in ny-or about 500$-
the kavent 731 has a $799 list price but ive seen the actual price of $599  from him on agon :o so for about 100$ you get  the  3 year warranty.
ctviggen
« Reply #23 on: 22 Oct 2004, 12:22 pm »
I really like the ShengYa.  This week, I'm comparing the ShengYa with using my Pioneer Elite DVD as transport to an Ack Dack.  Hey, what kind of tube do you recommend for the ShengYa?
rosconey
« Reply #24 on: 22 Oct 2004, 01:11 pm »
i have a telefunkin in it right now :mrgreen:
have tried a amperex also :o
ctviggen
« Reply #25 on: 22 Oct 2004, 01:47 pm »
Thanks!  I'll give one of these a try.  I think sometime toward the end of this year, I might take all my cables and send them to get cryoed.  I'll probably order a new tube so that I receive the tube prior to sending everything to get cryoed and I'll also have the tube done.  Other than this, though (and the Ack Dack if I like it), my next purchases are all going to be room treatments.
rosconey
« Reply #26 on: 22 Oct 2004, 01:56 pm »
i bought some treatments from 8th nerve seconds sale :mrgreen:
Anarchist
True cost
« Reply #27 on: 23 Oct 2004, 12:54 am »
Your review started off giving me hope since the unit in question, you claimed, cost $300. But it appears to be $350 plus $125 shipping. $300 sounds inviting but $475 is a different story. Could you clarify?
rosconey
« Reply #28 on: 23 Oct 2004, 10:40 am »
price and shipping went up recently :o
i paid 425$ total with tax before the increase-300$ for unit, 100$ shipping and 25$ tax.
guest1632
  • Guest
Re: True cost
« Reply #29 on: 24 Oct 2004, 05:33 am »
Quote from: Anarchist
ctviggen
« Reply #30 on: 25 Oct 2004, 10:56 am »
I also paid $425, but that was maybe two months ago.  I think this is a nice unit.  I'm comparing an Ack Dack D/A with it, and the ShengYa is pretty darn close, which is great when you consider that the Ack Dack is over $500, and that doesn't include a transport.
Colin^
    • http://groups.msn.com/TheColinandMarySueHopperFamily/shengyayourockmyworld.msnw?action=ShowPhoto&Pho
« Reply #31 on: 29 Aug 2005, 05:46 am »
:nono:
The build quality of Shengya puts most High Prices so called High End to shame. :roll:
halo
Re: shengya s10 tube cdp - the review-
« Reply #32 on: 3 Dec 2006, 01:45 am »
I have owned both the Sheng Ya CD-S10 & the Kavent CD-731. Cosmetic differences aside they are the same player.
They actually use two tubes. The 12AU7 is for the power supply and the 6922/6DJ8/7308 is for the output. I rolled a lot of different tubes through them and I preferred the Mullard 6DJ8 for the output and an RCA "Cleartop" 12AU7 for the PS.
They are very nice CDP's IMO. Great bang for your buck. I purchased both of mine used.
I've since upgraded to the new Sheng Ya S-10CS. It uses four tubes: (2) 6DJ8 (output), (1) 12AX7 (PS), & (1) 12AU7 (Headphone output).
A definite improvement over the old player in SQ.
Cheers!
PaulHilgeman
« Reply #33 on: 6 Dec 2006, 11:23 pm »
I had that player for a while too.
Upgrade the output caps too, it made a HUGE difference over the solens that were in there.
I really enjoyed it, I had it for about a year, and then started the quest for something better, it took another year, and there were some VERY high end offerings that I didn't like as much.  I was using an EH output tube.
-Paul
guest1632
  • Guest
« Reply #34 on: 6 Dec 2006, 11:34 pm »
-Paul
Hi Paul,
What caps and values did you change to what brand? So what did you get later? Thanks.
Ray
PaulHilgeman
« Reply #35 on: 7 Dec 2006, 01:43 am »
Standard Sonicaps, not platinums.  Same value.
I got an Ayre CX-7e.  IMO the best player south of 10K asside from the other Ayre players.
http://www.ayre.com/products_detail.cfm?productid=2
Pretty standard player, but a really good clocking system and output stage, and a power supply that looks more at home in a 100W amp.
No HDCD, No SACD, No DVD-A, just awesome redbook.
-Paul
guest1632
  • Guest
« Reply #36 on: 7 Dec 2006, 02:11 am »
-Paul
Hi Again Paul,
hmm, how much is that player? also, on the China player, aren't the platinum caps supposedly the better ones?
Ray
PaulHilgeman
« Reply #37 on: 7 Dec 2006, 02:19 am »
Not sure if the platinums were out then, and IIRC, they were 2.2uF, those would cost more than the player itself.
The Ayre is 2950.00, so 10x the cost!!! :scratch: !!!.  I paid much less than that, but if you are in that kind of market, you have to listen to it.  I compared it to quite a few and had it in my system for about a month before buying it, so I got a pretty solid audition in.
-Paul
PaulHilgeman
« Reply #38 on: 7 Dec 2006, 02:22 am »
Yes, that would be $480.00 worth of caps.  The caps in the Ronin don't cost quite that much!!!
guest1632
  • Guest
« Reply #39 on: 7 Dec 2006, 03:19 am »
-Paul
HI Paul,
Did you ever listen to the Rega Apollo CDPlayer? Just curious. Don't have 3K rolling around at the moment.
Ray
