shengya s10 tube cdp - the review-
0 Members and 2 Guests are viewing this topic. Read 19573 times.
BoemPaukeslag
Re: shengya s10 tube cdp - the review-
« Reply #40 on: 7 Dec 2006, 10:04 pm »
I have the same player, for about 3 years now, and have similar experiences - sound quality is just very good, and tube rolling will make a clear difference, at least for the output tube. I liked (Dutch) Amperex 7308 very much, and also NOS TESLA e88cc (goldpins and not JJ) sounded clearly better than the stock (philips) tube. The TESLA's gave me a slightly rounded low-end, but great, lucid highs. The 7308 have slightly more edge, but also go deeper, maybe less tube-like. Choosing between these two was merely a matter of taste rather than sound quality, however.
And even with the stock tubes, it sounds better than my tubed Marantz Heart 6000 (and check those reviews on the web!), deeper lows and sweeter highs, and HDCD! It may be a dying format, but cd's that do have it, show a better soundstage, so it's well worth it!
Only problem I had with was strange hickups in its sound. I was going to send it for repair, but I swapped the power supply tube -more or less for unclear reasons- and my problem was solved  :o.
ctviggen
« Reply #41 on: 8 Dec 2006, 12:49 pm »
Where do you get your tubes?  I compared my Shengya (wirh original tubes) versus my Bolder Cables-modified Squeezebox and my Ack Dack 2.0 DAC (using same interconnects on Shengya and DAC), and it was close.  I have the low end power supply from Bolder Cables, but the SB/Ack Dack combo still beat out the Shengya in realism and location of instruments/vocals in the soundstage, but it was darn close.  I had to listen for quite a long time to discern the differences (of course, once you hear the differences, they're then easy to pick out).  This was a much close test than other tests I've performed, where the SB/Ack Dack walks all over the competition.
halo
« Reply #42 on: 9 Dec 2006, 04:46 pm »
I get my tubes from Andy @ VTS: http://www.vintagetubeservices.com
Cheers!
guest1632
  • Guest
« Reply #43 on: 10 Dec 2006, 03:58 am »
Cheers!
Cheers!
Hi, Wow! reading through Andy's webpages sure almost wants you to go out and buy a piece of tube gear. I wonder if Frank from AVA has used his tubes..
Ray
