I listened to part of each of those two tube cuts earlier today and figured I had a bad connection or noise on my AC line. I just revisited and also listened to something else as a reality check.Trying to be diplomatic, I don't think these cuts are representative of much of anything. Tuan, please get another digital set-up to record this stuff. neo
Sonny,I don't want to belittle the point but that's an awesome rig you've got there and the clips don't do it justice.neo
My thought too! Also, recording it through a Canon camer ELPH 950IS is not ideal either, but you got to play with what you have, right?Thanks for the feedback!
Is there any tracking performance difference between the Zyx and Shelter?
Have not ever used a Shelter, but have found the ZYX to be an excellent tracker with my Moerch arm.
Tuan... "sometimes a man's gotta do what a man's gotta do!" Sounds pretty good too. I am still dialing it into "perfection." I am getting the most slight, and at times almost imperceivable, distortion during very dynamic passages in the right channel. It happens unexpectedly and at random places on different albums. It's gotta somehow be cartridge alignment and tracking, because as the hours go by, with each little micro adjustment I make, it gets better. To really dial this baby in... is going to a lot of patience. It's the most demanding cartridge I've owned and mounted... That being said... I gotta tell you, that it sounds real fine.
