0 Members and 1 Guest are viewing this topic. Read 14204 times.
PeteHave you tried moving the comfy theatre chairs backcalculating the listening positionyou may have a null where they are now
The last two posts are in favor of bigger bass drivers. Wouldn't this point towards dedicated subwoofers and not the SS12s? You could go to 13", 15", 18" drivers AND have placement options since they aren't co-located with your mids/tweeter in the SS12 cabinet.
Well....sort of. As I also posted earlier, I have yet to hear a system including subwoofers that perfectly integrated the subs with the rest of the speakers. With really diligent, systematic external EQ'ing and proper equipment, yes, it can be done. Remember, the subs and other speakers aren't 'tuned' to each other for a truly flat response such as you would find in quality speaker designer crossovers...where time and frequency domains are accounted for. And driver parameters and dynamics also play an important part in a seamless production of audio from LF to HF. I'm not sure mix and match subs and speakers can offer that.At least that's my story and I'm sticking to it.
Update: I replaced the tube preamp with my old Bryston sp1.7 prepro, using the 2 channel bypass only. I actually like what the solid state prepro did to the sound. I feel like some bass came back and the highs were a tad airier. Anyway I will keep this and move to the room acoustics/measuring when time permits. I have put bigger speakers on the back burner. Phil A, let me know when you are passing through and we can RTA room if I haven't gotten to it. I'll buy you dinner at a great local restaurant
