0 Members and 1 Guest are viewing this topic. Read 14203 times.
I feel like if I just add subs to the ss8s, I might as well kept the 803s and added subs to them.
So you don't think there is much sonic difference between the two?
I would like to second what Nuance and jtwrace have said: measure your room. This is absolutely critical for understanding what's happening in the low frequency department. I recommend that you stop thinking about speaker options entirely (seriously, set this issue aside 100 percent), and begin to learn about measuring your room. If you think about it, you already own speakers that put out substantial SPL down to fairly low frequencies. Yet, something seems to be missing. As Nuance said, this may be a null that you are experiencing. If so, upgrading to new speakers and placing them in the same location will likely produce a very similar null. Bottom line is that without measuring, you're missing key information needed to make this decision. It's just not worth remaining in the dark when making upgrades like this. Good luck.
.......From my experience with twin eights of that caliber on each side, his speakers should easily pressurize that room for music....
