0 Members and 1 Guest are viewing this topic. Read 10022 times.
Maybe, maybe not. Your question is meaningless without knowing the particulars of the system said preamp will be used in.Dave.
Well the "gain" could be current gain and not voltage gain. Also, gain could be negative and still considered voltage gain. Regardless, the original query is still impossible to answer. Sometime you want/need gain in a preamp and sometimes you don't.Dave.
Well the "gain" could be current gain and not voltage gain. Dave.
Davey man your post is impossible to follow,negative gain,current gain,impossible to answer,tell us more!!! gain in a preamp is not bad at all!!!
If you have speakers that are 100db efficient and a power amp with 32db voltage gain, is voltage gain in the preamp "not bad at all?" Dave.
Saved the best one for last...
It's just a general question to get a feel of how folks feel about the need for gain in a preamp.
