0 Members and 1 Guest are viewing this topic. Read 10031 times.
Not a bad question. I recently switched from a preamp to the Bent Audio TAP (bentaudio.com/index2.html), a passive device. My sources are vinyl, through an ss phono preamp (Dynamic Sound Associates-DSA- Phono One), and my computer, through an Ayre QB-9 DAC. Both have plenty of gain to drive my amps, so all I need is a really good volume control: i.e., the TAP. Really works great in my system.
Well the "gain" could be current gain and not voltage gain. Also, gain could be negative and still considered voltage gain. Dave.
If you have speakers that are 100db efficient and a power amp with 32db voltage gain, is voltage gain in the preamp "not bad at all?" Dave.
By the way, we can, and I suspect many other vendors can too, adjust the gain of our amps and or preamps to give you useful volume control rotation with very sensitive speakers. Its no big deal if we know you need this.Frank Van Alstine
I’m currently looking at a Bent Audio AVC-1 and that’s how my question came about. My current line stage preamp has 22db of gain which drives a bi-amp system thru an electronic crossover. The volume control (attenuator) goes from 7 o’clock to 5 o’clock. If I listen at the 11 o’clock position it is really cranking. The AVC-1 has a max gain of 7db I believe. Seems like 7db would be enough for my bi-amp system.
This is not the case today. We use digital source components with high gain stages and strong output voltage capacity, which in turn play hot recordings (always at 0dBfs peak and often compressed). Most of these dacs are robust enough to drive a power amp on their own. There is no need for more gain in this scenario (an active preamp).
I like my TVC a lot, but I would not recommend one (or an AVC) if you know for sure that you need 6dB of gain, or if you know that you will be using minimal attenuation (volume control near unity gain). The more attenuation you use, the friendlier a TVC becomes. I imagine an autoformer is similar.Typically you want a TVC set to -14 dB for the very loudest you would ever play your system. And that is without the +6dB engaged. When you attenuate a TVC between -14 and 0dB, the in/out impedance relationships fall apart and become unfriendly. At that point, you are really in active preamp territory.I'm not saying that an AVC/TVC at unity gain to +6dB won't work at all. I'm just saying that it will perform poorly compared to the way it performs when it is 20 to 40 dB down. That is really where they do their thing.
Hi Quiet Earth,Thanks for that info. Once I get my Pass B1 preamp built (buffered / 0 Gain) I'll have a better idea if I need additional gain or not.WN
You need to build a preamp with gain to have a better idea,if you build a preamp with 0 gain you wont be able to see the difference ,a gain of 2 is a good way to start, avoid 0 gain is no good way to see how a preamp is performing... what i have found is ,is better to have some cliping than to have limited gain in the pwr amp and preamp...
...Take note of the highest volume control position you ever utilize with your existing (22db) preamp. (Use some of your program material that you know to be recorded at lower levels.)When you've identified that position use a test CD or signal generator and voltmeter and measure the input and output voltages and determine the gain. That's the minimum gain you need. Cheers,Dave.
