0 Members and 1 Guest are viewing this topic. Read 5243 times.
....... i've heard these speakers sound amazing and I'm hoping to get close to it.
Are you saying that you already own them, and now you are trying to get them to sound as good as when you first heard them?Or are you saying that you have only heard that they sound good?
i have Acoustic Technologies speakers (http://www.acoustictechnologiesllc.com/).
Thanks for all the help. This is my first topic and my first few posts. I’m learning. I should have given more context and been clearer. Here’s an attempt.I already own these speakers. I heard them a few years ago at a show and loved them. The whole room was the sweet spot which is what I want.The problem was they were $2500 which I couldn’t and wouldn’t do. A couple of weeks ago, I saw them on ebay with no bids. I bid the minimum of $325 and forgot about it. A week later, I got notice that I won it for $325. No one else had bid. I have them and they’re mint.Needless to say I’m very happy about it and think it a steal. I tried the two solid state amps that I have. One, an Acurus 100 watt, was a horrible match with a flat, uninvolving sound.The second is a basic amp with volume control which was slightly better but not good. This is where the question of “gain” comes in.The electronics I heard them with was a Pass Labs X1 preamplifier and First Watt F3. I can’t afford these.My first question should have been ”do I need to have an active preamp?” is this the gain the reviewer was alluding to? I was thinking of the Rega Brio-r but I think the rega is not an active preamp. If I use a tube integrated, would (or could) this have an active preamp or would I need to go with a separate amp and pre-amp and dac.Ideally, an all in one amp, pre and dac would be ideal. Would the peachtree deco 125 have an active preamp? Nuforce DDA-100?I hope this gives a clearer picture. I really appreciate all the help.
He heard them hooked up to some Pass gear, which is well beyond what he wants to spend. Not to mention, I think he can easily find far less expensive gear that would satisfy his needs.A NAD 3020 might be an awesome place to start too. Super cheap. Not a ton of power on paper, but ballsy (2 ohm stable) and very warm and musical. That'd definitely get you started I would think. When you want to upgrade, selling your 3020 should be easy, as long as you get a good one to start with.
